Индикация Unifi LED status цветовое обозначение состояния | Ubiquiti форум UBNT: инструкции, настройка
Kadabifd
11 Сен 2017
Was this useful? Help us identify your favorite articles by clicking on the thumbs up at the bottom of the page. And if you think this article is not useful, please let us know why by clicking on the feedback link below!
Access Points, Security Gateways, Switches and Cloud Keys
Back to Top
Starting with Gen2 UAPs, we moved on to the Blue and White LED. USGs, UniFi Switches and Cloud Keys also use the same Blue and White LED patterns showcased in the table below, and they will mean the same thing. Legacy UAPs will have an Amber and Green LED on the front of the unit as seen in the Legacy section. Some products don't feature status LED patterns, such as the PoE Adapters.
Back to Top
White and Blue LEDs apply to:
Access Points UAP-PRO, UAP-Outdoor+, UAP-AC, UAP-AC-OD, UAP-IW, UAP-AC-LITE, UAP-AC-LR, UAP-AC-PRO, UAP-AC-HD, UAP-AC-EDU
Routing & Switching Cloud Key: UC-CK
Security Gateways: USG, USG-PRO-4
Switches: US‑24‑250W, US‑24‑500W, US‑48‑500W, US‑48‑750W, US‑24, US‑48, US‑8, US‑8‑60W, US‑8‑150W, US‑16‑150W, US‑16‑XG
Device Activity
LED Pattern
Initializing
AP is Booting
Flashing White / Off Every 1/2s
Factory Defaults
AP is Awaiting Adoption
Steady White
Adopted
AP is Broadcasting SSIDs;
Normal Operating Mode
Steady Blue
Initialization Error A12
Power Cycle AP and Contact Support if Recurring
Strobing White / Off
Firmware Upgrade
AP is Busy with Upgrade
DO NOT INTERRUPT!
Quickly Flashing White / Blue
Isolated
AP Lost Network Connectivity,
Searching for Wireless Uplink
Blue and Flashing Off Every 5s
Locating
The AP Locate Feature was Activated in Controller or the UniFi AC EasySetup App
Rapid Flashing Blue / Off
Device Offline
Verify Power, POE and Ethernet Cable
LED Off
Legacy Amber and Green LED
Back to Top
Applies to: UAP, UAP-LR, UAP-Outdoor5.
Device Activity
LED Pattern
Initializing
AP is Booting
Flashing Amber / Off Every 1/2s
Factory Defaults
Steady Amber
Adopted
Steady Green
Strobing Amber / Off
Firmware Upgrade
DO NOT INTERRUPT!
Quickly Flashing Amber / Green
Isolated
Green and Flashing Off Every 5s
Locating
Rapid Flashing Green / Off
Device Offline
LED Off
Back to Top
The various UniFi Security Gateways and UniFi Switches will have a different type, number and location of ports, please be sure to reference your specific model's Quick Start Guide (pages ~5-6, under the Hardware Overview section) for the exact location and description of its ports.
Console Port's right LED (in the applicable devices):
  • LED Off: Power Off
  • LED Green: Power On
Speed/Link/Act (right LED ports other than Console):
  • LED Off: No Link
  • LED Amber: Link Established at 10/100 Mbps
  • LED Flashing Amber: Link Activity at 10/100 Mbps
  • LED Green: Link Established at 1000 Mbps
  • LED Flashing Green: Link Activity at 1000 Mbps
PoE (left LED on ports of applicable devices):
  • LED Off: No PoE
  • LED Amber: IEEE 802.3af/802.3at
  • LED Green: 24V Passive
SFP (in the applicable devices):
  • LED Off: No Link
  • LED Green: Link Established at 1 Gbps
  • LED Flashing Green: Link activity at 1 Gbps
See specific port LED information in the Hardware Overview section (between pages 5 and 6) of the Quickstart Guides. You can find the QSG at the bottom of each product page of the USGs and Switches in the Routing & Switching section of the UniFi Product page.
Back to Top
The LED of the PoE Adapters are simple to interpret:
LED is Off - PoE is Off
LED is On and steady - PoE is functioning as it should
LED is blinking - this is not a configured state, this just might mean the device is not connected properly, or that something is wrong with the cable.
